java script error
Thread began 8/11/2009 5:35 pm by chssagmi366905 | Last modified 8/12/2009 12:01 pm by Jason Byrnes | 1857 views | 1 replies |
chssagmi366905
java script error
I can't install "add to cart" button because when it first asks in the radio button and I select the "get from recordset" option it gives me an error message stating "Ecart add to cart button while excuting onClick in WA eCart Add To Cart htm, a Java Script error occurred."
sometimes this error can occur if the columns in your table use SQL Reserved words for the name, Can you post a screen shot of the Table Editor showing the column names for your table?
I have also seen this in cases where the recordset returns fewer column than are in the eCart object.
