Making only certain cart items taxable
Thread began 2/27/2013 7:35 am by elewis93815 | Last modified 2/27/2013 8:01 am by Jason Byrnes | 648 views | 1 replies |
elewis93815
We have constructed a site that has tax added to only certain items, cupcakes are not taxed but catering items are taxed. Now they have added a link of macarons which are to be taxed. How do I change macarons to be a taxable item? www.cup-cake.com
Thanks,
Jackie
you will need to add a new column to the eCart object named taxable
in the add to cart button, set the value for the taxable column to 1 for items that should be taxed and 0 for items that should not be taxed
Then in the eCart object, set the tax rule up on the tax tab.
Set the trigger to "Number of items With A Specific Column value":
If the total Number of items where 'taxable' has a value of '1' is '>' than a value of '0'
Set the calculation to "based on items with a specific value":
Total of 'TotalPrice' where 'taxable' has a value of '1' 'times' '.10'
replace '.10' with the correct tax rate you wish to use.
