Dynamic Framework
Thread began 2/26/2013 6:50 am by jo271221 | Last modified 2/26/2013 7:35 am by Jason Byrnes | 584 views | 1 replies |
jo271221
Dynamic Framework
I want to display a dynamic home page from the table custom_pages. I have added that to my pages with framework builder with the intention of using the customer id from my members table. I can see some ID code in the page however I am obviously missing something as my page is displaying the 1st record in the custom_pages table NOT the record that corresponds to the customers id.
In home2 I am NOT specifying a column in custom pages and no content is displaying.
Ideally I would like to be able to trigger to a page and filter to a customer id.
My pages would be based on PageContentName=Home, About, Contact
On Home3 the framework page is filtered to PageContentName-Home
I have menu writer on the page which I am implementing dynamic links as well. (still working on that)
Home3.php?id=3810
Home2.php?id=3810
HotSiteAll.zip
your using circular logic in your page.
you are passing in an ID using a querystring:
Home3.php?id=3810
you have created a recordset to filter based on the query string id, you are then using the recordset ID column for the variable in the dynamic plugin
why not just use the URL id variable?
the problem is that the dynamic plugin code is before the recordset code, but in actual fact, you don't need the recordset, you only need to use the URL variable.
