Datepicker date not being added to database correctly
Thread began 2/25/2013 10:49 am by iainmacdonald331081 | Last modified 2/25/2013 12:47 pm by iainmacdonald331081 | 1159 views | 2 replies |
iainmacdonald331081
Not sure if I've done this right - I basically have an input field into a database like this:
<input type="text" name="Valid_From" id="datepicker_1" value="<?php echo KT_escapeAttribute($row_rsitineraries['Valid_From']); ?>" class="inputwidth300" />
With a Datepicker added with the ID date picker_1, with the JS in the header all looking present and correct.
The date picker itself works OK, and populates the input field with a date in the format:
02/14/2013
But the database is populated with : 0000-00-00
And 30 November -0001 is what is shown when the record is displayed on a page.
Basically why isn't 02/14/2013 added to the record?
The only thing I could think of is that it needs to be entered in the form:
YYYY-MM-DD
for the SQL?
Yes, my SQL Expects the date format to be yyyy-mm-dd. You will need to convert the date format before it is stored to the database, add the following code at line of your insert page page:
if(isset($_POST['Valid_From'])) $_POST['Valid_From'] = date("Y-m-d"strtotime($_POST['Valid_From']));
iainmacdonald331081
Thanks Jason, perfect.
