No database selected
Thread began 2/24/2013 10:25 pm by adamuabu445910 | Last modified 2/25/2013 10:07 am by Jason Byrnes | 338 views | 1 replies |
adamuabu445910
I created a page which allows user to log in and access information from a database. but on login in remotely, I get a "no database selected" error. it works perfectly locally. below is the code:
<?php require_once('Connections/sya.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['username:'])) {
$loginUsername=$_POST['username:'];
$password=$_POST['Password:'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "trainingindex.php";
$MM_redirectLoginFailed = "index.php";
$MM_redirecttoReferrer = true;
mysql_select_db($database_sya, $sya);
$LoginRS__query=sprintf("SELECT username, password FROM users WHERE username=%s AND password=%s",
GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $sya) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && true) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
you posted this in another thread, see my reply to the other thread:
showpost.php?p=146182&postcount=10
