ecart stop working
I can get the eCart working if its installed on its own. As soon as I install Design Extender or Data Bridge it stops working. Can any one help with this.
is eCart giving an error message?
What version of eCart?
what version of Dreamweaver?
please provide some more details on the problem.
Ah sorry I guess more info mite be helpfuly
Using dreamweaver CS6 and the eCart is 5.0.6, Design extender is 1.1.1 and then Data Bridge is 1.1.3. There is no error massage's. The only thing I get is when installing the extensions it asks to overwrite some files which webassist says to say "yes to all".
The only way you know that its not working is the buttons don't highlight as I have maked in the image below.
Do you have a site defined in Dreamweaver?
Do you have a php page from the site open when you try to access the eCart Object window?
What is the build number of the Dreamweaver version you have installed?
Is it the Creative Cloud version?
The php was working had used the other extensions to build.
Found out the problem, I think it was just a bad install of dreamweaver. After a reinstall every worked from the start.
So happy days.
thanks for the replies all the same
ok, glad to hear it is working.
