SQL "users" table set up error
I have tried to run the sql script on my server running php 4 and 5. when i try to run the script i receive the following error:
Error
SQL-query :
CREATE TABLE `users` (
`UserID` int( 11 ) NOT NULL auto_increment,
`UserEmail` varchar( 500 ) default NULL ,
`UserPassword` varchar( 500 ) default NULL ,
`UserFirstName` varchar( 50 ) default NULL ,
`UserLastName` varchar( 50 ) default NULL ,
`UserCity` varchar( 90 ) default NULL ,
`UserState` varchar( 20 ) default NULL ,
`UserZip` varchar( 12 ) default NULL ,
`UserEmailVerified` tinyint( 1 ) default '0',
`UserRegistrationDate` timestamp NULL default ‘CURRENT_TIMESTAMP’,
`UserVerificationCode` varchar( 20 ) default NULL ,
`UserIP` varchar( 50 ) default NULL ,
`UserPhone` varchar( 20 ) default NULL ,
`UserFax` varchar( 20 ) default NULL ,
`UserCountry` varchar( 20 ) default NULL ,
`UserAddress` varchar( 100 ) default NULL ,
`UserAddress2` varchar( 50 ) default NULL ,
PRIMARY KEY ( `UserID` )
MySQL said:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'defaultCURRENT_TIMESTAMP, `UserVerificationCode` varchar( 20 ) default NULL , ' at line 1
Please let me know how to solve this issue. the code above has syntax issues. please advice.
Thank you,
Marco
877 392 2682
