url parameter naming
Thread began 2/15/2013 3:50 am by john70964 | Last modified 2/15/2013 9:22 am by john70964 | 998 views | 2 replies |
john70964
I notice that when I create a link to a dynamic url sometimes it seems not to work with
the ID field name eg "RecordNumber"
When "RecordNumber" is the autoincrement record number
e.g. Detail.php?RecordNumber=<?php echo $row_rsQuick_Search['RecNo']; ?> would not find the record in one instance. Using "RecordNumber" usually does work OK
I tried
Detail.php?recordID=<?php echo $row_rsQuick_Search['recordID']; ?>
and this found the Record OK
Is it preferred to use the field name "RecordNumber"
or just use recordID.
Many thanks
John
it depends on what URL Variable name the recordset is expecting.
if you create the link to pass the ID variable using the name RecordNumber, you need to make sure the recordset on the Detail.php page is looking for that URL variable name.
the key is to make sure the links and the recordset are using the same name for the URL variable. if the recordset is looking for the recordID URL variable and you pass it as RecordNumber, that wont work.
john70964
I think I understand OK but can never remember using recordID on a detail page but have needed to use it in parameters twice.
I will now know what to look out for .
Many thanks
John
