File Upload php on IIS
Thread begun 2/12/2013 4:13 pm by Vikingbear | Last modified 2/13/2013 5:27 pm by Vikingbear | 6791 views | 3 replies |
Vikingbear
Hi, I have tried all combinations of directories and links to helper.php file.. these are the mesages I am getting! Is this a server setting I have not applied?? ANy sugegstions are greatly appreicated!
PHP Warning: move_uploaded_file(C:\inetpub\wwwroot\2013.downunderdive.com.au\admin\images\top_slider\44b0c289479eea271d16895c0d15024a_tmp.jpg) [<a href='plugins/function.move-uploaded-file'>function.move-uploaded-file</a>]: failed to open stream: Permission denied in C:\inetpub\wwwroot\2013.downunderdive.com.au\WA_DigitalFilePro\HelperPHP.php on line 96
PHP Warning: move_uploaded_file() [<a href='plugins/function.move-uploaded-file'>function.move-uploaded-file</a>]: Unable to move 'C:\Windows\Temp\phpB5E2.tmp' to 'C:\inetpub\wwwroot\2013.downunderdive.com.au\admin\images\top_slider\44b0c289479eea271d16895c0d15024a_tmp.jpg' in C:\inetpub\wwwroot\2013.downunderdive.com.au\WA_DigitalFilePro\HelperPHP.php on line 96
PHP Warning: copy(C:\inetpub\wwwroot\2013.downunderdive.com.au\admin\images\top_slider\44b0c289479eea271d16895c0d15024a_tmp.jpg) [<a href='plugins/function.copy'>function.copy</a>]: failed to open stream: No such file or directory in C:\inetpub\wwwroot\2013.downunderdive.com.au\WA_DigitalFilePro\HelperPHP.php on line 98
This error means that the upload folder does not the appropriate write permissions to allow the uploaded file to be saved.
you need to edit the permissions of the upload folder to allow write access,
Vikingbear
File Upload
Hi Jason
Thanks for your reply, I will go and check permissions..
I notice the code writes to a 'temp' folder and then moves the file to the final destination folder.. the temp folder sits 'below' the website root, does this one need special permissions as well? and is it safe to give write access to a folder on that level of the server??
Thanks again!
Vikingbear
Solution:
Hi Jason
It works fine, thanks again..
We had a bunch of 'users' in the server settings, and the only one we had not given write permissions to the folder was the 'important' one apparently :)
Regards, Ken
