Encrypting Customer Data
Thread began 2/11/2013 1:11 pm by jason363662 | Last modified 7/25/2014 11:53 am by Jason Byrnes | 1072 views | 9 replies |
jason363662
I understand how to use security assist to encrypt password information created during the sign-up process but I'm wondering if I can use SA's built-in encryption tools to encrypt other data stored to my database. For example, my users will be able to keep a contact/customer list on my site - I would like to encrypt all related data. Can I use SA to help me do this? Thanks!
be aware that data encryption is one way, meaning once encrypted the data cannot be decrypted. It is not intended to encrypt and decrypt the data.
so if you encrypted the first name for example, you would not be able to display the unencrypted first name on the page.
jason363662
Are you sure?
If your plugin only handles encryption, how is it that when I use your password recovery utility the system sends me my username and password (now decrypted) via email?
I understand if it's not possible to use SA for encrypting/decrypting other data, but this might be a feature you should consider adding. I imagine many of your users would benefit by being able to secure db information outside of just the login process.
Thanks, you guys are the best!
in security assist 2, the forgot password sends the user to a page to reset their password,
in security assist 1, you could create a forgot password page that would create a new random password, send that password in the email, then encrypt it and store the new random password in the database, it was decrypting what was already there, it was creating a new one, and sending that.
jason363662
Am I doing someting wrong?
I'm assuming I have SA2 - I have the latest SuperSuite running on DW CS6. I show Ecart 5.0.6 and databridge 1.0.3 (not sure which contains SA)
I've run through the whole process - create new username & pw, login, logout, request pw. The system emails me the following:
Password Information
Your username and password were requested from our website. They have been recovered and are listed below:
Username: j*****m
Password: testpass1
(I asterisked my username - the system sent it in full)
I can see that the password is being stored in the database hashed as requested, but it definitely seems like it's being decrypted and sent back to me.
Am I being obtuse? I don't mind it working this way - I just want to make sure my passwords are securely encrypted.
if it is emailing you the password, you are not using encryption.
if you where using encryption, the forgot password page would send a link for you to reset the password.
only if the password is not encrypted will it send an email with the password, because the password cannot be decrypted.
jason363662
Are You Sure? Are you really, really sure?
Something isn't jiving - digging a little deeper I found that I can format uploads through databridge to encrypt using several different formats and that I can then format on the recordset binding to show the data decrypted (see attached).
This is working to do exactly what I wanted to do and asked in my original question, that is, encrypt user entered data and decrypt when I need to display it.
I can see the data in my MySql database, and it is definitely encrypted.
In other words, it seems that I can indeed use Security Assist to encrypt and decrypt data.
I feel like I've been on a bit of a wild-goose chase in this thread with you insisting that I can't use SA to accomplish what I was hoping and then having to discover on my own that I can.
Or maybe we have a fundamental miscommunication happening somewhere.
I stand corrected, the HASH and RIJENDL encryption types are capable of being decrypted, these are very uncommonly used however,
the other encryption types which are more commonly used, especially for password encryption, are one way encryption types that are not able to be decrypted.
Art
Jason, by "one way" you mean it can still be tested and matched (in the case of a password), it just can't be decrypted and displayed again. Is that correct?
yes, you can still test the password entered by the password in the database by encrypting the entered password,
"One Way" encryption means it cannot be decrypted
