Defaulting to Unlimited Inventory
Thread began 8/11/2009 12:09 am by Nigel | Last modified 8/15/2009 12:26 am by Nigel | 872 views | 2 replies |
Nigel
I don't want to use the inventory feature and would like to remove it and have it default to "unlimited". Is it as simple as setting the paragraphs to display: none and setting the checkbox to checked? Will I introduce errors if I remove the rest of the code?
Thanks.
Dani Chankhour
You should not have to remove any code.
If you don't want to use Inventory, then just make sure to check the Unlimited Inventory check box. If you want this checkbox always checked, then add this to your check box input field (line 477 of your product insert page):
checked="checked"
Nigel
Thanks Dani, that did the trick.
