Security Assist redirect
Thread began 2/04/2013 2:29 pm by john70964 | Last modified 2/06/2013 4:11 am by john70964 | 647 views | 8 replies |
john70964
I have a directory with a
menu.php page which links to a Search Page
also a
Results Page and an
Update page
For administration purposes.
When any of the above pages are used without going via a login page the user is redirected to a Login page.
I want the Login Page to redirect to the MenuPage.
In the box
"If login Succeeds, go to" I have this set to menu.php
If open the results page first it redirects me to the login page. OK
When I login I am directed to the results page and not the menu page.
I am attaching the login page and the results page. Perhaps someone can see what may be incorrect here?
Many thanks
John
DarylBeta Tester
Im not sure if this will help, but I would suggest to try going to the behaviours panel when login.php is open, open the SecurityAssist Authenticate User behaviour and ensure that the redirect option is unticked in the Redirect section for 'Go to previous URL (if it exists) and see if that helps.
john70964
Thanks Daryl
Yes both of the tick boxes are unticked.
DarylBeta Tester
Hmm, I will leave this one to Jason then...
This code on login.php
"successRedirect" => "../Consul/menu.php",
"failRedirect" => "loginfailed.php",
"gotoPreviousURL" => FALSE,
"keepQueryString" => FALSE
Says that if you login correctly you should go to "../Consul/menu.php" and if you fail your login you should go to "loginfailed.php". It shouldnt remember your previous URL (gotoPreviousURL" => FALSE) or Query String (keepQueryString" => FALSE)
The code on update_results
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("../Login/loginfailed.php");
says that if you are not logged in, you will get sent to "../Login/loginfailed.php"
john70964
Thanks again Daryl
All helps in the learning of.
John
in the webassist/security_assist/heler_php.php file, change lines 51-53:
if (isset($_GET['accesscheck'])) {
            $WA_Auth_Parameter["successRedirect"] = urldecode($_GET['accesscheck']);
if (isset($_GET['accesscheck']) && $WA_Auth_Parameter["gotoPreviousURL"]) {
john70964
Thanks Jason
That code change seems to have sorted out the problem.
I have placed the files on the server and it throws up an error as follows:
Warning: Cannot modify header information - headers already sent by (output started at /home/username/boat-for-sale.co.uk/Login/login.php:11) in /home/username/boat-for-sale.co.uk/Login/login.php on line 76
Warning: Cannot modify header information - headers already sent by (output started at /home/username/boat-for-sale.co.uk/Login/login.php:11) in /home/username/boat-for-sale.co.uk/Login/login.php on line 81
Warning: Cannot modify header information - headers already sent by (output started at /home/username/boat-for-sale.co.uk/Login/login.php:11) in /home/username/boat-for-sale.co.uk/Login/login.php on line 96
Warning: Cannot modify header information - headers already sent by (output started at /home/username/boat-for-sale.co.uk/Login/login.php:11) in /home/username/boat-for-sale.co.uk/Login/login.php on line 101
Warning: Cannot modify header information - headers already sent by (output started at /home/username/boat-for-sale.co.uk/Login/login.php:11) in /home/username/boat-for-sale.co.uk/webassist/security_assist/helper_php.php on line 56
Sounds rather like the error I had earlier with the UEMail.
I have zipped and attached the file and hope you may be able to see the problem.
Many thanks
john
change line 9 - 11:
<![CDATA[@@OldIncludeCode@@]]>
john70964
Thanks Jason
Worked very well
Regards
John
