How To Use Forms As Plugin In Framework Theme
Thread began 2/04/2013 1:35 pm by Cologne | Last modified 2/04/2013 2:24 pm by Cologne | 885 views | 7 replies |
Cologne
Hello,
I want to use a simple contact form as plugin in my framework theme.
What action do I have to use in the form?
When I leave it blank i redirects to a page not found page.
What is the trick to use contact, registration or login forms as plugin in a framework theme?
Cheers
Denis
use the following code for the forms action:
 action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlspecialchars($_SERVER["QUERY_STRING"]):""?>"
Cologne
;-) thanks, I just found it :-)
showthread.php?t=27130
Cologne
it looks like this is not working :-(
kontakt.php
attached the files.
Denis
Plugin.zip
not working in what way?
It seams to be redirecting to the thank you page on when i test it.
Cologne
yes it just shows the same page
Go To page: contact.php?sent=true
but this page is not longer in the framework theme
well, the theme page is kontakt.php right?
so that is the page that should be used as the email go to page:
Go To page: ../kontakt.php?sent=true
Cologne
Perfect :-)
Thanks a lot!
Denis
