DataAssist Pages - Dreamweaver Template?
Thread began 2/04/2013 9:25 am by sandy170299 | Last modified 2/04/2013 11:37 am by sandy170299 | 717 views | 4 replies |
sandy170299
I want to use a DW Template to base my administrative pages on. With the previous Data Assist, I used to be able to apply a DW Template when creating the pages. How is this accomplished with Data Bridge? Thank you.
you need to apply the template after the pages are created.
on each page, go to Modify -> Templates -> Apply Template to page
alternatively, you could create pages based on the template, then add the data assist pages to them using Framework Builder Plugins.
sandy170299
Thanks. I was hoping there was a way to assign a template to the pages during the wizard, like there was before.
Can you explain how this can be done? Is there a tutorial?
"alternatively, you could create pages based on the template, then add the data assist pages to them using Framework Builder Plugins."
No, there is not a tutorial for this.
you create a page based on the template, then add Framework builder plugin:
WebAssist -> Framework Builder -> Plugins
you can either use a static plugin and create a page from the template for each data assist page, or you could use Dynamic plugins, where you only have one page and change the plugin being used base on a url variable or similar.
sandy170299
I'm not sure I'm following this, but I will give it a try.
