Log In
Thread began 1/30/2013 8:28 am by Php | Last modified 1/30/2013 1:44 pm by Jason Byrnes | 509 views | 4 replies |
Php
Log In
On the login page if the user gets the password incorrect the following message comes:
The password doesn't meet the specified strength. Your field must contain: a minimum of 6 and a maximum of 500 characters, a minimum of 3 and a maximum of 500 alphabet characters, and a minimum of 2 and a maximum of 500 numbers.
Thats a long message to display, how do I reduce it?
view the page in design view, you should be able to see the error message test and edit it directly.
if you don't see it, you may need to go to code view and do a search for the error message to finds it and edit it.
Php
Thanks, I've been able to do that.
Php
customer registration
Hi, two customer registration forms have been created on the registration page, as I had to create the pages again. How would I delete one of the forms as I have tried but I'm unable able to identify where the second form begins.
I would delete the pages, then re run the wizard, the duplicate forms are only the start, the login behaviors, the inserts and updates all will be duplicated as well.
