Set multiple default WA folders locations?
Thread began 8/10/2009 6:51 pm by michellem310468 | Last modified 8/10/2009 6:57 pm by Jason Byrnes | 1014 views | 1 replies |
michellem310468
I am having a recurring problem when adding or applying changes to Universal Email, iRite, Validation Toolkit, or other WA program. As an example, I have the WA_Universal_Email folder in two locations on our site - one in the root directory, and one in a distant sub-directory that relates to a non-public section of our website. This was done to keep things organized given the complexity of our site. However, when making changes within WA to pages located in the sub directory, WA defaults to saving changes to the WA files in the root folder. If I change the links within a file to point to the sub directory folders, upon any changes made to WA settings (email, validations, etc.), it will rewrite these links to point back to the root files.
Obviously, this has caused a lot of problems. How can I set the default location for saving/linking WA files so that it's always RELATIVE to the page file, and not always saving to the root location?
Thanks.
The location will always use the root of the defined site.
For example, if you define a site at:
www.mydomain.com/
The WA Folders will always be created at the root.
If you want the WA Folders to be in a subdirectory:
ASubFolder
you must define a site that uses:
ASubFolder
as the root. This can get tricky to manage however, since the sub directory "ASubFolder" will be a member of both site, you will need to remember to only make changes to the pages in that sub directory using the second site that was defined for:
ASubFolder
