Multiple list search - No results
Thread began 1/27/2013 11:19 am by joblackmon445409 | Last modified 1/28/2013 9:04 am by Jason Byrnes | 610 views | 1 replies |
joblackmon445409
So I have tried Data Assist Page to create Search, Results, and Details page. I populate my lists from a dynamic table form MySQL database (also tried dynamic database option) that has lists of the fields I want to search. ALso, I can't even get 1 Search criteria to work and display results for menu. I CAN get 1 search criteria to work for TEXT, but not two. I have also tried only creating results and details page then using data search wizard to make search form, which again didnt work.
I want to search STATES and Physician SPECIALTIES: I use a drop down menu to select the STATES and Specialties. I have tried to manually populate drop down and also dynamically populate drop down from dynamic database and MySQL database on localhost. When ever I search there are always no results. I use the results page generated from Data Pages.
I would appreciate any help with this as I have been trying for 2 days or more.
I have attached my searh, results, and details pages in .zip file.
Thanks for helping in advance.
Search.zip
in the search page you have sent the state and and specialty select lists do not have any values?
I'll need to see a copy of the pages where you are populating the select lists in order to see how they are getting their values.
also, it would be helpful to have a link where i can see the problem in the browser.
