Data Assist Html Editor
Thread began 1/23/2013 2:01 pm by neil444064 | Last modified 1/24/2013 1:02 pm by neil444064 | 1899 views | 10 replies |
neil444064
I used DA to create my Insert Update pages etc. but the html editor that is generated in the configure fields area does not have an option to add images. Can you tell how to change this editor? I already have my pages created and they work nice.
in the pages, select the HTML Editor instance, in the property inspector, click the edit button to edit the HTML Editor instance.
from the preset manager list, select one of the Files Manager enabled presets.
neil444064
I get this error when I click edit see attached image. I am not sure if you can see full size the js error.
The screen shoot is to small to read the javascript error.
either crop the image to include just the error, or compress the image to a zip file.
neil444064
new image cropped.
see this post for a copy of the Configuration\Objects\Forms folder that should correct the error
showpost.php?p=137837&postcount=9
neil444064
Hello Jason I appreciate the help but now I get this error I replaced all the contents from the forms folder. BTW in CS6 it is not in us-EN but here C:\Program Files\Adobe\Adobe Dreamweaver CS6\configuration\Objects for anyone else who encounters this problem. See attached
no, that is _not_ the correct location, adding it in that location is the cause of the error.
It needs to go in the Users configuration folder, not in the application configuration folder.
if you need help locating the users configuration folder, see the common installation issues page:
common_installation_issues.php
neil444064
Did I destroy my DW? I completely replaced the folder.
hard to say really. it may that you need to unisntall DW then reinstall it.
