Adding/moving fields causes DW to crash
Thread began 1/21/2013 11:24 am by info4753 | Last modified 2/01/2013 9:34 am by Jason Byrnes | 1887 views | 7 replies |
info4753
When I add multiple fields into f.e. an insert page (DataAssist create pages / Manage pages) or move or delete fields, DW immediatly crashes.
Also when I create a completly new insert page and add multiple fields at once, DW. crashes. If I only add 1 field it does not crash.
I've got the newest extensions installed. MacOSX 10.8.2. and DW CS 6 newest version.
Thx for any help
What application preset are you using?
if you are not using a preset, do you have the same problem if you do try top use a preset?
Does DW Crash immediately after adding or removing a column? or does it pause for a second trying to redraw the preview?
Maybe try disabling the preview through the WebAssist Preferences panel.
info4753
I'm using a DataAssist preset.
Crashing happens also when I'm not using a preset.
I switched the preview off, but DW still crashes.
It takes about a second after some field reordering until DW crashes.
Sometimes DW crashes just after adding multiple fields, most of the time after reordering one or more fields.
i am not able to reproduce this issue
submit102797
DW Creashes
I am having the same problem. I have added a field to the database and now I am trying to regenerate the forms but when I do, as soon as the _Results page is generated, it crashes and does not generate the other pages. I am using the latest version of DataAssist and DW 6.
Dave
tom.kurshinsky298027
I just discovered this as well but slightly different. I have an insert page that was working fine but when I add a list box and try to set it for dynamic data, it crashes immediately.
Here is the problem details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Dreamweaver.exe
Application Version: 9.0.0.3481
Application Timestamp: 4600622f
Fault Module Name: Dreamweaver.exe
Fault Module Version: 9.0.0.3481
Fault Module Timestamp: 4600622f
Exception Code: c0000005
Exception Offset: 002dab57
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
