Modifying First Form
Thread began 1/19/2013 6:46 am by eabooth445224 | Last modified 1/21/2013 3:53 pm by eabooth445224 | 608 views | 2 replies |
eabooth445224
I am a new user trying to modify my first form using CSS Form Builder 2.0.1 and DW CS6. I am trying to follow the instructions 'Reentering the interfaces' by clicking once on the outline of the form but I do not see 'Edit Form' in my Properties Inspector.
CSS Form Builder 2 is not compatible with Dreamweaver CS6, it has been replaced with Data Bridge which includes CSS Form Builder and all of our Other Data Driven extensions.
If you select the first form element in the form, then in the tag selector, select the form tag, that should also trigger the edit button in the property inspector.
eabooth445224
cs6 modify form
Jason
I bought Data Bridge so that is not the problem. I understand what I was doing wrong.
--thanks
Ernie
