PS 4.5 database tables
Thread began 1/18/2013 1:26 pm by massimo173451 | Last modified 1/18/2013 1:38 pm by Jason Byrnes | 433 views | 1 replies |
massimo173451
Hi there, where I can find the database file for installing it on my apache local server???
Massimo
the best way to create the power store tables on your local system is to run the power store install script.
otherwise, you can create the tables by running the install/scripts/db.sql file on the MySQL server.
