PowerCMS and Dreamweaver Responise Design Feature
Is this widget compatible with DW CS6 responsive web design template? In other words, if I use the fluid grid layout template and save it in a .php file will it work?
This seems like a pretty simple answer. Yes or no. Is there no one who can help me with this?
Thanks.
yes, you can add CMS Content to a responsive design.
However, the CKEditor will not generate responsive content, you will need to edit the styles for the content that it adds to make it responsive.
Thank you, Jason. I always appreciate your help. :)
