CS6 and JavaScript errors
Thread began 1/14/2013 10:27 am by jstoler155201 | Last modified 1/14/2013 11:08 am by Jason Byrnes | 854 views | 1 replies |
jstoler155201
I am using Dreamweaver CS6 with many of the WA stand alone extensions installed. The one problem is that everytime I open Dreamweaver, I get a series of javascript errors in regards to Layout manager in which the message is "wa is not defined". Then I get three in a row about WA_Memento.htm, all referring to an undefined "RefreshUI", "Resize" and "_mementoNotifications". Then the Memento window opens in mid-screen, and it is blank. How can I make this go away?
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
