products insert.php
Thread began 1/13/2013 7:32 pm by dennis0120174338 | Last modified 1/15/2013 9:33 am by Jason Byrnes | 698 views | 3 replies |
dennis0120174338
products insert.php
I have just purchased super suite and followed the tutorial "Integrating Data bridge and eCart". I have worked through some initial problems like installing extensions in the right order and deleting cache file etc. When I complete the above tutorial the products_insert.php page has no content or "form" in the body section...there is a lot of code in the head section, but nothing shows up as an insert form. All other pages seem to be alright.
Also how can all of the created pages be inserted into css sculpture designed pages.
Make sure that you are using Data Bridge 1.1.2. if you have a previous version make sure that you uninstall it from the extension manager before installing the newer one.
save the CSS Sculptor design as a template, add a main content editable region to the template, then apply the template to the pages created by data assist
dennis0120174338
products insert.php
Hello Jason,
Thanks for your quick reply on the css sculptor template information.
I am using Data Bridge 1.1.2 it is my first purchase so I do not have a previous version.
I tried the whole tutorial again and get the same result (no content in body section of product insert page) I did notice this time that when webassist was creating the admin pages a notification popped up on the products insert page creation saying that "this file was modified outside of dreamweaver, do you want to continue"
That notification will pop up if the page that is being created by the wizard already exists and is open in Dreamweaver.
When you run the create pages wizard, double check on the manage pages tab that the pages to be created are using unique names.
