Call Dynamic Plugin from a Plugin
Thread began 1/12/2013 6:58 am by Mike Perry | Last modified 1/15/2013 11:28 am by Jason Byrnes | 1351 views | 5 replies |
Mike Perry
I have a Products page that by default loads a plugin named prodmain.php. prodmain.php contains only images that are to be links to the various products pages.
Can I call plugins for products.php from prodmain.php, which is loaded into products.php?
I want to load all plugins into products.php so that the main product menu item remains "current" for all product items.
Thanks,
Mike
i dont understand, that sounds like it would create an endless loop?
maybe i am missing something, but if you have a page named products.php, then add prodmain.php to it as a plugin, adding products.php as a plugin to prodmain.php will just cause the plugin system to loop around endlessly.
Mike Perry
Yes it would.
I want to call a plugin FOR products FROM prodmain. In other words, I want to REPLACE prodmain IN products with a plugin called FROM prodmain.
Hope that's clearer. . . :-)
Thanks,
Mike
I dont see why that would not work, you should be able to use a dynamic plugin inside of a plugin page.
Mike Perry
Can I call the new plugin for products from prodmain??
i dont see why not.
