Create links in a repeat region
Thread began 1/11/2013 10:02 am by zackdacre445052 | Last modified 11/14/2013 1:22 pm by anonymous | 5092 views | 13 replies |
zackdacre445052
I am quite new to Dreamweaver and need some assistance. I have created a repeat region displaying names from a database. I would like to link each name to a separate Word document that can be downloaded in a web browser. Thanks for your assistance.
is the name of the word document stored in the database table that is driving the repeat region?
you can easily add a link through the property inpsector.
highlight the name field, open the property inspector, in the link field, click the folder icon, set the link to use Data Sources, and select the recordset column that holds the word document name.
zackdacre445052
links in repeat region
The name of the word document is not stored in the database. Do I need to store the name of the word document in the database table for this to work? thanks
if the link will be different for each record, than yes.
zackdacre445052
Thanks much! It worked out perfect.
anonymous
Links in repeat region
Hi Jason,
I am not sure if you are still available to answer this question. I am now CS 6 and the links do not work anymore. Any suggestions. Thanks much.
Need ore details please.
How are you creating the links? in what way do they not work?
Can you send a copy of the page please.
anonymous
<?php require_once('Connections/Hosting.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_Hosting, $Hosting);
$query_Applicants = "SELECT namelist.name, namelist.Occupation, namelist.id FROM namelist ORDER BY namelist.name";
$Applicants = mysql_query($query_Applicants, $Hosting) or die(mysql_error());
$row_Applicants = mysql_fetch_assoc($Applicants);
$totalRows_Applicants = mysql_num_rows($Applicants);
$query_Applicants2 = "SELECT namelist.Occupation, namelist.id FROM namelist ORDER BY namelist.name";
$Applicants2 = mysql_query($query_Applicants2, $Hosting) or die(mysql_error());
$row_Applicants2 = mysql_fetch_assoc($Applicants2);
$totalRows_Applicants2 = mysql_num_rows($Applicants2);
$query_Applicants_details = "SELECT namelist.name, namelist.Gender, namelist.address, namelist.NIC, namelist.Highest_Qualification, namelist.Occupation, namelist.CV_name, namelist.id, namelist.Picture FROM namelist ORDER BY namelist.name LIMIT 2";
$Applicants_details = mysql_query($query_Applicants_details, $Hosting) or die(mysql_error());
$row_Applicants_details = mysql_fetch_assoc($Applicants_details);
$totalRows_Applicants_details = mysql_num_rows($Applicants_details);
$var1_Applicants_details3 = "-1";
if (isset($_GET['id'])) {
$var1_Applicants_details3 = $_GET['id'];
$query_Applicants_details = sprintf("SELECT namelist.name, namelist.Gender, namelist.address, namelist.NIC, namelist.Highest_Qualification, namelist.Occupation, namelist.CV_name, namelist.id, namelist.Picture FROM namelist WHERE namelist.id = %s ORDER BY namelist.name ", GetSQLValueString($var1_Applicants_details3, "int"));
}else{
<head>
<script src="http://use.edgefonts.net/sarina.js"></script>
<title>PC Services</title>
<link href="Style/Style.css" rel="stylesheet" type="text/css" />
<script src="SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
<link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
<style type="text/css">
a:link {
text-decoration: none;
a:visited {
a:hover {
a:active {
</style>
</head>
<body>
<div id="header">
<h1>PC Services </h1>
<h2><img src="Images/chip.jpg" width="113" height="103" alt="chip" />&quot;Solutions through Technology&quot;</h2>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>Services&gt;Career&gt;Job Applicants</p>
</div>
<div id="menu">
<ul id="MenuBar1" class="MenuBarHorizontal">
<li><strong><a href="index.html">Home</a>
</strong> </li>
<li><strong><a href="#">Products</a></strong></li>
<li><strong><a class="MenuBarItemSubmenu" href="#">Services</a>
</strong>
<ul>
<li><a href="Advertising.html">Advertising</a></li>
<li><strong><a class="MenuBarItemSubmenu" href="career.html">Career</a> </strong>
<ul>
<li><strong><a href="Job_applicants.php">Job_Applicants</a></strong></li>
<li><strong><a href="Occupational_groups.html">Occupational_Groups</a></strong></li>
</ul>
</li>
<li><strong><a href="Repairs.html">Repairs</a></strong></li>
<li><strong><a href="#">Upgrades</a></strong></li>
</ul>
</li>
<li><strong><a href="#">News</a></strong></li>
<li><strong><a href="#">Contact Us</a></strong></li>
</ul>
<form id="NIC" name="NIC" method="post" action="Search_NIC.php">
<p><strong>
<label for="search">SEARCH NIC#</label>
<input type="text" name="NIC" id="NIC" />
<input type="submit" name="submit" id="submit" value="GO" />
</strong></p>
</form>
</div>
<div id="home_2">
<h2>Job Applicants</h2>
<div id="name">
<h3>Name</h3>
<?php do { ?>
<p><a href="Applicants.php?id=<?php echo $row_Applicants['id']; ?>"><?php echo $row_Applicants['name']; ?></a></p>
<?php } while ($row_Applicants = mysql_fetch_assoc($Applicants)); ?>
</div>
<div id="occupation">
<h3>Position</h3>
<?php do { ?>
<p><?php echo $row_Applicants2['Occupation']; ?></p>
<?php } while ($row_Applicants2 = mysql_fetch_assoc($Applicants2)); ?>
</div>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
</div>
<div id="home_3">
<h2>Applicants Details</h2>
<?php do { ?>
<p><strong><em>Name&gt;&gt;&gt; </em></strong><?php echo $row_Applicants_details['name']; ?></p>
<div id="picture">
<p><img src="<?php echo $row_Applicants_details['Picture']; ?>" /></p>
<p>&nbsp;</p>
</div>
<p><em><strong>Address &gt;&gt;&gt;</strong></em><?php echo $row_Applicants_details['address']; ?></p>
<p><em><strong>NIC#</strong></em>&gt;&gt;&gt; <?php echo $row_Applicants_details['NIC']; ?></p>
<p><em><strong>Gender&gt;&gt;&gt;</strong></em> <?php echo $row_Applicants_details['Gender']; ?></p>
<p><em><strong>Occupation&gt;&gt;&gt;</strong></em> <?php echo $row_Applicants_details['Occupation']; ?></p>
<p><em><strong>Highest Qualification&gt;&gt;&gt;</strong></em><?php echo $row_Applicants_details['Highest_Qualification']; ?></p>
<p><em><strong>Download CV&gt;&gt;&gt; </strong></em><a href="<?php echo $row_Applicants_details['CV_name']; ?>"><?php echo $row_Applicants_details['CV_name']; ?></a></p>
<p>&nbsp;</p>
<?php } while ($row_Applicants_details = mysql_fetch_assoc($Applicants_details)); ?>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
</div>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<div id="Footer">
<p>&copy; PC Services Page last updated Friday, October 25, 2013</p>
<p>&nbsp;</p>
</div>
<p>&nbsp; </p>
var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgDown:"SpryAssets/SpryMenuBarDownHover.gif", imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
</script>
</body>
</html>
mysql_free_result($Applicants);
mysql_free_result($Applicants2);
mysql_free_result($Applicants_details);
A copy of the page is above. I created a link to a word document using the property inspector and data sources and the database field containing the name of the word document in the repeat region. The results return the name of the document but when I try to download the work document it gives an error.
"but when I try to download the work document it gives an error."
what is the error?
I cant help without knowing what the error says. No way to troubleshoot an error by knowing only that is exists, I need to know what the error says.
anonymous
Object not found!
The requested URL was not found on this server. The link on the referring page seems to be wrong or outdated. Please inform the author of that page about the error.
If you think this is a server error, please contact the webmaster.
Error 404
localhost
Apache/2.4.4 (Win32) OpenSSL/1.0.1e PHP/5.5.3
This is the error above.
