Single upload...multiple type output [jpg, png...]
Thread begun 1/11/2013 8:52 am by alnico431299 | Last modified 1/11/2013 9:08 am by Jason Byrnes | 964 views | 1 replies |
alnico431299
I can upload a single file (no modifications) and save it as:
I also want is to save another version as type (jpg):
In a single 'Upload Files' script I cannot create files with multiple extensions (a limitation).
So...
If I create two ''Upload Files' scripts that take the SAME input form field (fileName)...the first one writes the file the second does not create the file.
If they are two separate form fields pointing to the same image (fileNameA = image.png, fileNameB = image.png) it works fine...but this is not kosher as the image is the same.
Any insight/solutions?
No, digital file pro is not designed to create two versions of the same file with different extensions.
