Page updated sucessfully
Thread began 1/09/2013 2:43 pm by neil444064 | Last modified 1/09/2013 3:52 pm by Ian S | 392 views | 1 replies |
neil444064
Hello, I used data assist to creat my update page and everything works fine except after the page is updated (update btn pressed)there is no indication that the page is updated. How do I set up a message to say "sucessfully updated"? Thanks
Ian S
There are a couple of ways you can do this. Either using a URL value or a Session Value.
Probably the easiest is to use URL, as you can define this in the Server Behaviour redirect. Add a value to the URL string such as manage.php?success=1 and then on the manage.php page you would have a conditional region that shows only if the URL value of success is present and equal to 1.
Cheers
Ian
