editing PowerStore in Dreamweaver
Thread began 1/09/2013 2:16 pm by lee341019 | Last modified 1/09/2013 2:22 pm by Jason Byrnes | 502 views | 1 replies |
lee341019
Hi, Is it possible to edit all the CSS in DW. Eg. make main image larger??
Also, are the following options available/possible to add
1. add more than one image per product?
2. can the images be cropped?
3. add a zoom tool to images?
yes, you an edit the CSS files for your theme within dreamweaver.
they are located in webassist/themes/your_theme
1) when adding a product, only one image can be used as the product image, but in the description, the last toolbar button allows you to add a gallery.
if you create a gallery, you can add it to the product long description.
2-3) the gallery does not support croped images or using a zoom tool.
