$WA_redirectURL - proper syntax
Server Behavior - WA DataAssist Update (using Data Bridge)
What is the proper syntax for this expression?
$WA_redirectURL = "activity_groups_results.php?group_id=".$_SESSION['group_id']."";
When I use the above expression and attempt to edit the server behavior, I get this Dreamweaver error message:
"It appears that one of your server-side values is improperly coded.
Please check this interface for inconsistencies."
If I remove -- .$_SESSION['group_id']."" -- from the line, the error message does not appear.
