Powerstore template customization
So, I've decided to give PowerStore a go and am working through the "Using a Custom Template in PowerStore" tutorial to see how that turns out when using it with an existing site template.
So far I have found one glaring omission:
- Open the install directory of your PowerStore
- Open the webassist folder
- Open the themes folder
- Duplicate the Default folder
- Rename the newly created duplicate folder "NewTemplate"
- Open the PowerStore admin
- Set NewTemplate as the default theme
In between 5 and 6 you will be asked if you want to 're-link' the files to the newly named directory with a pop-up. DO NOT DO THIS as it breaks the template!
