databridge / dataassist conflict maybe?
Thread began 1/09/2013 10:30 am by Patrice | Last modified 1/09/2013 12:14 pm by Patrice | 806 views | 3 replies |
PatriceWebAssist
Hi... I'm working on an older site where I originally set up an admin using data assist. In that version i believe it used lower case naming for results, update etc.
I have moved to databridge 1.1.2, and my latest redo of some of the pages are giving me upper case file naming. Results, etc...
Even when I delete the older pages, and reload the newer ones, the links go back to lower case, which are no longer on the site. So the links from results to update, insert, delete are not working.
So thinking a library or helper page is interfering, I am wondering of the WA_DataAssist, WA_DigitalFilePro should be deleted, and then I should recreate the pages that I need to make changes to. I hesitate to just delete as many areas of the admin are still functioning done in the older model. I did uninstall in the extension manager.
Screen shot attached of the folders/directories I am asking about.
PatriceWebAssist
I did a fix for now: I opened the Results, Detail, Insert, Update pages and did find and replace for all the lower case. That solved it. But curious why it happened and if I need to remove those older folders.
Thanks...
In the data assist wizard, you can set the names of the pages that will be created on the manage pages tab
you can set the pages to be created to use uppercase, or lower case on that page.
PatriceWebAssist
Yep... I did but the link backs weren't going to created names... very odd. I'll test on a clean site next week and see what it does without the older pages.
Thanks Jason.
