]]> instead of form field
Thread began 1/07/2013 10:37 am by Sally | Last modified 1/07/2013 11:50 am by Jason Byrnes | 539 views | 1 replies |
Sally
I am creating a form using the preset Simple Contact where the only mod is to remove the CAPTCHA, but leave the Answer field, and a Basic Design where the only mod is to change it to 600 px wide. During the build I get an error (see Capture.jpg) which isn't very descriptive.
I noticed in the preview, before I built it, I had these ]]> characters instead of the form field but I was thinking they'd go away. Wrong.
I get it even if I start with a blank page or use another preset. I've attached my Contact page for you to look at.
Thank you for any help.
EDIT: I figured out the problem. I had installed E-cart this morning and it must have messed up some files. I uninstalled Data Bridge, reinstalled it and I have form fields back now. :)
contact.zip
eCart should be installed after Data Bridge.
Data Bridge should be the last extension installed.
