multiple error messages in Security Assist setup
Thread began 1/07/2013 12:27 pm by Brendan | Last modified 1/07/2013 2:23 pm by Jason Byrnes | 379 views | 3 replies |
Brendan
I have run through the wizard, and am getting an error on virtually every page with security applied to it.
First - login.php (login.php)
error message
:Fatal error: Call to undefined function virtual() in /home/ltacorg/public_html/test/mainpages/login.php on line 4
line 4 of that page - <?php virtual('/Connections/userdatabase.php'); ?>
I replaced ' with " and that had no effect
On one of my secured pages (boardmeetings.php)
Error Message:
Fatal error: Call to undefined function virtual() in /home/ltacorg/public_html/test/memberpages/boardmeetings.php on line 1
Line 1 of that page -<?php virtual( "/webassist/security_assist/helper_php.php" ); ?>
I don't really know enough about php to provide any other information. Any help is greatly appreciated!!
Dreamweaver is using the "virtual" syntax because in your Site Definition, the "Create Links Relative To:" option is set to Site. If you change that to "Document" instead, Dreamweaver will use the "require_once" syntax.
Brendan
Thanks Jason, that worked.
One last question. How/Where do I edit the form validation for the password? I found the WA Server Validations server behavior but not anywhere that I can remove password required length, or strength
in design view, select the password filed, the click the blue bounding box around it, this will open the Spry settings in the property inspector top allow you to change the length requirements.
