Server Validation - Restrict Content
Thread began 1/07/2013 8:15 am by Ian S | Last modified 1/08/2013 12:45 pm by Ian S | 3599 views | 5 replies |
Ian S
Hi
I have setup a Server Validation to restrict the content of a field. The reason for this is that the field defines the page name and URL and I need to prevent pages being called Gallery or Images as it would mess the .htaccess file up.
However, even though the behaviour is set as exact match it still fails validation if someone creates a page called 'Saturdays Gallery' for example, so its like its using the 'Includes' operator rather than 'Exact'
Is this a bug or am I doing something wrong?
Cheers
Ian
the restrict content validation looks at each word individually.
it is intended to restrict specific words from being used in the entry.
using the includes validation type would look within a word:
"thegalery"
would fail the includes validation type, but not exact validation.
Ian S
OK, Jason. Thanks. That makes sense.
Is there a way to achieve what I want using the WA Server Validations?
Basically - if someone entered the work Gallery that would be a fail but if someone entered the word Image Gallery that would be OK.
Cheers
Ian
Ian S
Hi Jason,
I've hand coded some validation to get around my problem so it's no longer a pressing issue, but it would be good to know if there is anything I can do with the server validations to achieve being able to restrict a word being used in a singular fashion.
Cheers
Ian
use a regular expression.
here is a regular expression that will restrict galley or Gallery as a singular word, but will allow "gallery123" or "saturdays gallery" to be entered:
/^((?!^((G|g)allery)$).)*$/
you could add Images and images to the restriction as well using:
/^((?!^((G|g)allery|(I|i)mages)$).)*$/
Ian S
Ah, Brilliant!
Thank you as always!
Cheers
Ian
