Adding 'browse server' option for image attachments
Thread began 1/06/2013 3:15 am by CraigR | Last modified 1/08/2013 10:33 am by Jason Byrnes | 1673 views | 8 replies |
CraigRBeta Tester
i am creating an event planning site, and have added the option of associating an image with each event - using file manipulation->upload on my form.
This is working ok, but i see the scenario where I want to re-use some previously uploaded images.
How can I add a 'browse server' option to my form, (eg using a file manager similar to powercms or html editor) so that I have the option of uploading a new image if required, but using an existing one if it already exists ?
Do I need to hand code or is there a form tool to help ?
Use the file manager that is available with Data Bridge.
WebAssist -> Forms -> Insert File Manager
CraigRBeta Tester
oh, I don't have that option
CS6, Databridge 1.0.6
the current version of Data Bridge is 1.1.2, please install the most recent version.
CraigRBeta Tester
ok, i updated to 1.1.2, and whilst I was at it, updated design extender to 1.1.1.
The option now appears in the menu, (has it been there long ?), but nothing happens when I select it.
I tried all other form options from the menu, and they all seem to work
Tried creating a new page, adding a form first, ...still nothing
try using the insert bar instead.
go to windows -> Insert
in the insert bar, select the WebAssist category, then click the Insert file Manger button.
I'll log a bug that the access point under the web assist menu is not working.
CraigRBeta Tester
ok, that gets me started
Not sure how to use it yet, but I'll have a go and see how I get on
CraigRBeta Tester
I tried adding an instance of file manager to an existing insert page and after a bit of trial and error, got it working.
All of my images are stored in a folder called images, which I have set in my Power CMS server settings.
When i click on an uploaded image, i get the folder and image name added to the text field.
So far so good, and I some further questions for which I cant find answers in the help.
  • Can I restrict the view of the folder to display only images, (it may contain several file types such as pdf as well) ?
  • Is there a setting where i can return only the image name and not the full path, or do i have to strip the string with a bit of manual coding ?
  • Can i change the maximum size parameter from 1024 * 768
No, the file manager cannot be modified to show only images.
No, the file manager will always return the full path
you can change the max file dimensions allowed by editing the the webassist/kfm/initialize.php file:
$kfm->defaultSetting('max_image_upload_width', 1024);
$kfm->defaultSetting('max_image_upload_height', 768);
