How do I remove images that are successfully uploaded
Thread begun 1/05/2013 7:26 am by mrs | Last modified 1/07/2013 8:20 am by Jason Byrnes | 1286 views | 1 replies |
mrs
If I have successfully created an insert and update system to upload images to a single record, how do I enable a user to delete an image associated with the record without actually deleting the whole record.
Obviously, a successful update page has a hidden field which the user is unable to edit, therefore is unable to remove the image.
Any thoughts?
add a second form to the update page with a hidden element and a submit button to delete the file.
aset the valuer of the hidden element to sue the File Column from the recordset on the update page., then add a delete file behavior. In the delete file behavior, use the Delete File button as the trigger, and the hidden element as the file name.
