Embed link in email
Thread began 1/02/2013 2:11 pm by vincent.rycx336448 | Last modified 1/10/2013 6:47 am by vincent.rycx336448 | 2556 views | 4 replies |
vincent.rycx336448
Embed link in email
Using UE,
I can email a link of this type: <a href=http://www.mysite.com/myfile.php>Select</a>
but not: <a href=http://www.mysite.com/myfile.php?ID=$id>Select</a>
Thank you for your help.
Vince
$id is a php variable? if so, you need to add php code to echo the php variable:
<a href="http://www.mysite.com/myfile.php?ID=<?php echo $id?>">Select</a>
vincent.rycx336448
Hi Jason,
I tried that already whithout succes
Here is the code in /email/waue_...
$MailBody = $MailBody . "<a href=\"http://www.mysite.com/myfile.php?ID=";
$MailBody = $MailBody . $id;
$MailBody = $MailBody . "\">Select</a> ";
where does the $id variable get set?
I'll need more details please.
A copy of the page that Universal Email is applied to would be helpful so i can see where and how the $id variable is being set.
do you get an error message on the page?
or does the link in the email not contain the $id value?
please be as detailed as possible.
vincent.rycx336448
I have redone the process after deleting the waue... file. It works now.
Sorry and thank you Jason, One learns to be humble when working in this field.
