Are we limited to how many lines/characters we can have
In PowerCMS Builder is the page length limited to a set number of lines and or characters? Client adds information, and it is truncated from what he wants on the page.
in the Power CMS Database, the ContentValue column of the pcms2_contents table uses the Text data type. A text column can store a maximum of 65535 bytes. If this is not enough for your uses, you can edit the table structure and change the data type to MediumText which stores a maximum of 16,777,215 bytes, or LongText which offers a 4G maximum size.
Thank you Jason, once I READ what you said it was a breeze!
