Home page extra space
Thread began 12/31/2012 7:16 am by massimo173451 | Last modified 1/29/2013 5:35 am by massimo173451 | 1666 views | 4 replies |
massimo173451
Hi Jason, I need to reduce the extra space(showed by the arrow in the image attached) for fit the slideshow in the CSS frame, in the home page www.tessyacconciature.it, what can I do for reduce this extra space???
Thanks a lot
HAPPY 2013!!!!
Massimo
you asked this in another thread last week.
see my reply to the other thread:
showthread.php?t=29547
massimo173451
Jason, the space is referring using IE,Firefox or Safari browser with strange behaviours (see the arrow in the images attached for clarify the issue), not to images showed in the slideshow. In the image attached in IE the space, in the main frame where the slideshow is placed, is correct, instead in Firefox is greater.Thanks for your reply.
looks like there are a couple of empty paragraph tags after the gallery.
edit the content area that the gallery is in and remove the empty paragraph tags.
massimo173451
Works great now!!!! Thanks Jason for your support
