Template linking
Thread began 12/28/2012 11:51 am by john70964 | Last modified 12/29/2012 2:08 am by john70964 | 1371 views | 5 replies |
john70964
Template linking
I have a .php template
The template contains a file, header_basic.php containing a WA menu at root level
When I use the template in pages at root level the menu works correctly.
However when I use the template in a page within a folder down one level ie ../MyFolder the menu does display as a graphical item but only as words
EG
Customer 1
Photo 1b
Photo 1c
Photo 1d
Photo 1e
Customer 2
Photo 2a
Photo 2b
Photo 2c
Photo 2d
Photo 2e
Customer 3
Photo 3a
Photo 3b
Photo 3c
Photo 3d
Photo 3e
I am attaching code from a barebones page within the folder and wonder if anyone can see how to display the graphical face.
It seems the template works only on pages at root level.
I did try changing
<!-- InstanceBegin template="/Templates/general.dwt.php
to
<!-- InstanceBegin template="../Templates/general.dwt.php but it did not solve the problem
But it did not seem to change anything.
Many thanks
John
untitled.zip
can you send a link where i can see the problem in a browser please.
john70964
Wo is me
I dont have it on a remote server at the moment Jason.
john70964
I think I have found an answer to this
Instead of including a header file in the template I built the menu within the template and that seems to work.
So will try more tomorrow.
Regards
John
are you adding the header file to the template using require_once()? that would cause the problem since paths will not be changed using require_once(), it is better to just add the menu to the template rather than trying to create a separate page for it.
john70964
Thank you Jason
Yes you are exactly right and I will proceed as you say.
Regards
John
