Validation is not working on user name field
On this page, login.php, the login validation isn't working. User name should be a required field, but it's not prompting me to enter a value on submit if the field is left blank. Thanks!
Highlight the text field and go to Insert->Spry->Spry text field, and you can add validation that way.
Do you mean the spry validation text field?
Yes. That will be an easy way to quickly add validation to that text field.
