Help with double opt in reg
I am at the following step of the web assist tutorial. - I open login.php and no SecurityAssist Authenticate User server behavior exists in my behaviors pane. Should I add these or should WA have put them in when I used the wizard to create the pages?
Step from tutorial below: data_bridge_create_double_opt_in_reg.php
Store verified status on login
I can only imagine your excitement as you ready yourself for this incredible task.
1.Open the login.php page.
2. In the Server Behaviors panel, open the first SecurityAssist Authenticate User.
3. Change to the Session Values tab.
4. Click the Plus (+).
5. Select emailVerified.
6. Click OK.
7. open the second SecurityAssist Authenticate User.
8. Change to the Session Values tab.
9. Click the Plus (+).
10. Select emailVerified.
11. Click OK.
12.Save the page.
