Slide Show customization
Thread began 12/15/2012 12:54 pm by massimo173451 | Last modified 12/20/2012 7:37 am by Jason Byrnes | 955 views | 7 replies |
massimo173451
In the home page, is showed a gallery slide slow but the images are not fitted (bigger) inside the slide show frame, is available a method for avoid this issue?? I have already changed the index.php in the galleries/slideshow_wide but without success (change only the external slide show frame but the images are bigger). How is possible instead customize the home page using an external slide show??? Here is the link: www.tessyacconciature.it
Massimo
What version of power gallery are you using?
In power gallery 2, you can go to the Choose design Page, then for the design you are using, click the settings link to edit the gallery settings and change the image sizes.
massimo173451
Is not Power Gallery but PowerStore 4.5.3
Thanks Jason
see this thread for details on resizing the gallery images in power store:
showthread.php?t=27932
massimo173451
Thanks Jason, but for using external Slide show in PS 4.5.3 is there a method for this???
Massimo
I dont follow, the thread i linked to has details for resizing the Power Store gallery images.
massimo173451
Sorry for misunderstood, but I mean if is possible use a Slide show of third parties???
Massimo
It may be possible, it depends on the gallery. if it is javascript based, it should work, but there is no guarantee.
