Extensions do not appear
I upgraded to the new super suite for CS6, but no extensions appear in CS6. I specifically want to use siteimport, but it doesn't appear. Any help here?
In dreamweaver CS 6, go to Commands -> Manage extensions to open the extension manager. are the extensions listed there?
if not, click the install icon and browse to the MXP file you downloaded to install them.
if they are, you can access them from the WebAssist menu in Dreamweaver.
are you opening the extension manager form the Commands menu in Dreamweaver?
are the extensions checked (enabled) in the extension manager?
if the extensions are enabled you should have a Dreamweaver menu right next to the Window menu
Yes, its checked and enabled. There is no web assist extensions in Dreamweaver
