PowerStore Advanced product options - Only update options check box not working
Thread began 12/13/2012 8:34 am by pupweb | Last modified 12/13/2012 11:40 am by Jason Byrnes | 561 views | 1 replies |
pupweb
Hi WA community,
I have PowerStore 4.x installed. The PowerStore Advanced product options - Only update options check box is not working properly. I assume If want to update all the products regardless of options, I uncheck this box. When I do this it doesn't work. Am I missing something here?
[quote]I assume If want to update all the products regardless of options, I uncheck this box.[/quiote]
that's not quite how it works. If you uncheck the "Only Update <option name> Options" checkbox, then update the short description, for example, the change will apply to that product for all options in that category.
For example, if I create a Product and add an advanced option for size, and add Small Medium and Large as options. I can either have a unique short description for each options, or i can uncheck the "Only Update Large Options" check box and enter a short description that will be used for that product in all sizes
