Code to stop entire page from loading. Is this possible?
Thread began 8/09/2009 10:18 am by mjc309098 | Last modified 8/10/2009 2:24 pm by Jason Byrnes | 1942 views | 3 replies |
mjc309098
Hello;
I want to start by thanking tech support for helping me with the problem in my map.
I would like to do one last thing to tihs before I leave it alone. Right now, I have to have it set up so that the form is first, then the map under that then the directions stream in after the map.
I am trying to make it so when you submit your departure address, it doesn't load the whole page and you have to scroll down. I want it to load onto the directions part of the page.
Is this possible? I read another post out here that someone tried it, said they have a script that works, I tried it, and it isn't working, but it doesn't throw any errors either.
Here is the code:
function updateInfoWindow() {
wagmp_directions_1_obj.markers[0].openInfoWindowHtml
</script>
<cfform id="address" name="address" method="post" action="">
<cfinput type="text" name="addr" ID-"addr">
<cfinput type="text" name="city" ID-"city">
<cfinput type="submit" name="Submit" validateat="onSubmit" onClick="wagmp_directions_1(document.getElementById('address').value+', '+document.getElementById('city').value)" value="Get Directions" />
<!--- here is my div tags for maps --->
<div id="wagmp_map_1" style="width: 400px; height: 400px;"></div><div id="wagmp_directions_1" name></div>
</form>
Can anyone help me on this? I know it can be done, like I said, there is no errors, but it doesn't work. I also still get my directions, still have to scroll down.
This is written in ColdFusion.
Thank you.
The page needs to reload for the posted information to get to the map.
you could add an anchor just before the map div:
<a name="myMap" id="myMap"></a>
and change the forms action to go to the anchor:
<cfform id="address" name="address" method="post" action="#myMap">
This will cause the page to scroll down to the anchor when the form posts.
mjc309098
The # throws an error in coldfusion. I tried this approach. lol
know any other ways?
ahh, right it's a CFFORM tag, use two ## instead to escape the first:
<cfform id="address" name="address" method="post" action="##myMap">
