PowerCMS - Converting site to PHP from HTML
Thread began 12/11/2012 7:21 am by trucktire302476 | Last modified 12/11/2012 12:53 pm by Jason Byrnes | 775 views | 2 replies |
trucktire302476
I have some websites that I created in Dreamweaver CS4 using both CSS and HTML templates. Every page was created using templates for consistency.
I want to use PowerCMS which does not appear to be working I believe due to not having PHP pages. Do I need to convert all my template created HTML pages to PHP? If so, what is the simplest way for me to do so and how would I convert my HTML templates?
Also, will I need to set up a testing server for this?
Thanks,
trucktire302476
JavaScript Error
I also get this error everytime I open and close Dreamweaver:
The following JavaScript error(s) occurred:
Unable to open script file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\WebAssist\Momento\Library\WA_UserInterface_v2.js" (error 3).
This error has been happening for over a year. How can I fix this?
Thanks again...
to convert the site to php, you would need to rename each page using the .php file extension.
You will need to define a connection to a testing server in the DW Site definition, but that can set to use your remote server, it does not need to be a local testing server.
for the error, what extensions including version numbers are installed?
What is your DW Version? What is your OS?
