0 error ... Anyone else getting this?
Thread began 12/10/2012 8:17 pm by jamie.ghio444407 | Last modified 12/28/2012 1:38 pm by Jason Byrnes | 1034 views | 6 replies |
jamie.ghio444407
1. Open php page
2. Create record set for email addresses
3. complete and get the attached error.
looks like most files create but the main file is * and no form fields on the page.
win 7
DW cs6
Please help. I need to build a newsletter system. Thanks!
Have you installed the latest update to Data Bridge, version 1.1.0?
What Extensions including version numbers do you have installed?
jamie.ghio444407
Yes I downloaded and re-installed fresh and in this order. (last night)
Data bridge
Extender
Ecart
Free tools
Still same error.
I purchased this last friday, so I should only be using the latest files unless you guys put newer ones in the download center over the weekend.
Data Bridge should be installed last, I recommend this order:
eCart
Design Extender
Free Tools
Data Bridge
jamie.ghio444407
I will give it a try and update the thread with my results.
jamie.ghio444407
I have reinstalled all extentions in the order listed but still seem to get this error when going to webassist - creat email - (setup fields) click Finish - get 0 ERROR.
I am currently doing this tutorial data_bridge_create_double_opt_in_reg.php and when I get to the first part that is adding the email to the registration page, I set all the setting per the tutorial and click finish and the error pops up. It still creates the Blank.php email page and when I press the ok on the error I can save the registration page. I'd like to know if everything that is supposed to happen before the error occurs happens so I am attaching the registration file so you guys can see weather or not there is an actual issue or not. Thanks!
registration.zip
This was a troubleshooting alert left in the 1.1.o Data Bridge build, we released a newer version 1.1.1 to fix the problem.
it is really just a nuisance alert and should not effect functionality tough if you ignore it.
