Redirect failure on insert
Thread began 12/10/2012 4:58 pm by nickj | Last modified 12/11/2012 8:55 am by Jason Byrnes | 647 views | 2 replies |
nickj
Error from the top of the page:Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/breastsu/public_html/registrant/index2013.php:1) in /home/breastsu/public_html/_php/_startup.php on line 36
Notice: Use of undefined constant session_start - assumed 'session_start' in /home/breastsu/public_html/registrant/index2013.php on line 8
Warning: Cannot modify header information - headers already sent by (output started at /home/breastsu/public_html/registrant/index2013.php:1) in /home/breastsu/public_html/registrant/index2013.php on line 188
Why no redirect?
Nick
index2013.php.zip
Ian S
Hi Nick,
You have white space (output) between PHP tags on line 1 before <?php, line four after ?> and also at Line 97.
First thing to do is try removing them and see if it fixes the issue.
Cheers
Ian
Like Ian has pointed out, the white space at the beginning of line 1 and end of line 4 needs to be corrected.
also at line 8, you have incorrect syntax for the session_start() function. line 8:
session_start;
should be:
session_start();
to prevent posible header already started error's, I prefer to suppress errors on the session start call by using this code:
@session_start();
